2021-07-13 08:44 AM - last edited on 2021-09-14 09:00 AM by Noemi Balogh
DIM myArray[][] myArray[1][1] = 500 myArray[1][2] = 510 myArray[2][1] = 600 myArray[2][2] = 610 myArray[2][3] = 620 myArray[3][1] = 700 myArray[3][2] = 710 myArray[3][3] = 720 myArray[3][4] = 730VARDIM1(myArray[1])
2021-07-13 08:48 AM
2021-07-13 08:52 AM
2021-07-13 09:04 AM
2021-07-13 09:07 AM
dushyant wrote:What do you call sub-array? Could you refer to GDL manual page about (and provide AC version)? Because one of us does not understand it correct.
Because I need the size of the sub-array myArray[1] (that is the value 2 in my example) and not the entire parent array myArray
2021-07-13 09:15 AM
Podolsky wrote:Yes, but I don't need that.
So, VARDIM1(myArray) will give you 4 and VARDIM2(myArray) will give you 3.
2021-07-13 09:25 AM
2021-07-13 09:28 AM
2021-07-13 09:29 AM
Derived Types
Variables and parameters can also be arrays, and parameters can be value lists of a simple type.
Arrays are one- or two-dimensional tables of numeric and/or string values, which can be accessed directly by indexes.
2021-07-13 09:31 AM
