GDL
SOLVED!
Make Section View only show cutted geometry on the cutting plane
Martin Walter
I'm using a 3D geometry made up from EXTRUDE commands for the section view.
But the section always shows a lot of lines that are not directy cut by the cutting plane. These lines are from geometry behind the cutting plane.
I already played with the masks of the EXTRUDE command. But I can not see any difference using different masks.
Is there a way to only show the cutted geometry that is on the cutting plane?
(left is the actual section view - right the desired view)
AC22-27, Windows 11, i7-1355U, 32GB RAM, 2TB SSD
11 REPLIES 11
Lingwisyer
Guru
Change your line Status to 1 in the Extrude to hide lateral edges?
Martin Walter
Yes that is the solution of course!
