GDL
Mirror objects boolean in GDL
Hi all,
I'm relatively new in GDL and creating scripts.
I was looking for how to create a mirror parameter in existing AC library parts through GDL scripting, so the object can be mirrored with a simple click, rather than mirror the geometry manually (for instance, a sink but with the door turning the other way).
I came across commands and variables like MULX, SYMB_MIRRORED, but I can't really put together how to create a checkbox parameter to mirror the object.
Is there a simple GDL script for this?
Thanks!
1 REPLY 1
All objects already have a 'mirror' option - one click and the entire object is mirrored.
This sets the SYMB_MIRRORED value.
No need to do anything in GDL.
If you want to mirror the sink but not the door in a single object, then yes, you need to use MUL commands flip the part of the object in the direction you want (both 2D and 3D scripts).
Create a boolean parameter 'flip_sink'.
2D script...
IF flip_sink = 1 then
MUL2 -1,1
sink script here
DEL 1
ENDIF
3D script...
MULx -1
sink script here
DEL 1
ENDIF
