Lingwisyer
Guru
Multiply by Boolean? Interpreting Equation in Equation?
_doorHeight = _panelHeight + frameWidth*(iFrameType = FRAME_WIRE)
This line is from one of the broken GS AC23 objects. Anyone know how the highlighted section works? Changing the Equal to a Not Equal fixes two of the options, but doubles the issue in the third.
When GS rewrites an object, not adding anything, as far as I can tell, and breaks part of it...
Ling.
1 Solution
the highlighted section is returning a true or false value (1 or 0).
therefore the frame width is only added to the door height if the frame type is wire
therefore the "frameWidth" is only added to the "_doorHeight" if the "iFrameType" is "FRAME_WIRE"
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
Go to post
3 Replies 3
What object are you looking at?
Lingwisyer
Guru
Ah. Thanks Kristian.
So in this case, since changing the requisite to false solves the two false cases and doubles the true case, the equation should be a subtraction of frameWidth instead of addition. Simple fix, now just to wait for a licence to become available to use...
@Barry, Wardrobe Modular
Ling.
