Multiply by Boolean? Interpreting Equation in Equation?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-08-28
05:04 AM
2022-09-26
10:46 PM
Daniel Kassai
2020-08-28
05:04 AM
_doorHeight = _panelHeight + frameWidth*(iFrameType = FRAME_WIRE)
This line is from one of the broken GS AC23 objects. Anyone know how the highlighted section works? Changing theEqual to a Not Equal fixes two of the options, but doubles the issue in the third.
When GS rewrites an object, not adding anything, as far as I can tell, and breaks part of it...
Ling.
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
Solved! Go to Solution.
Labels:
- Labels:
Library (GDL)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-28 07:24 AM
2020-08-28
07:24 AM
the highlighted section is returning a true or false value (1 or 0).
therefore the frame width is only added to the door height if the frame type is wire
therefore the "frameWidth" is only added to the "_doorHeight" if the "iFrameType" is "FRAME_WIRE"
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-28 05:17 AM
2020-08-28
05:17 AM
What object are you looking at?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-28 07:24 AM
2020-08-28
07:24 AM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-28 08:11 AM
2020-08-28
08:11 AM
Ah. Thanks Kristian.
So in this case, since changing the requisite to false solves the two false cases and doubles the true case, the equation should be a subtraction offrameWidth instead of addition. Simple fix, now just to wait for a licence to become available to use...
@Barry, Wardrobe Modular
Ling.
Ling.
