GDL
Own window
jarkwiat
I've just created my own window but can't get rid of these lines on the arc
ArchiCAD 27 POL FULL iMac 20,1 Intel Core i5 3,1 GHz 24GB RAM AMD Radeon Pro 5300 4 GB
6 REPLIES 6
You need to look at status codes in the gdl pdf.
jarkwiat
Thanks, i'll look over there...
Just to clarify, it is the status code of the WALLHOLE or WALLNICHE command.
I am pretty sure it is the 64*j7 status that needs to be set to on (one) for the nodes at the start and end of the curve.
jarkwiat
It took me a long time but I found a solution. It is different than your suggestions (but thank you for your help anyway) and that's what it is about.
In the 3d script window I added a value of 64 to the wallhole coordinate - and that's it
I don't know if it's the right solution but it works !!!
Isn't that what we said back in March?
jarkwiat
Yes, indeed, I don't know how I might have missed it
