GDL
Param-O, define objets' own origin?
hi,
How do I rotate an object around a specific point?
For example around a point/ vertex of another object.
thanks for any hint!
BR, Florian
AC24 4018 INT, Win10, Quadro P2000, Xeon, BIMCloud
Viktor Kovacs
Hi Florian,
We definitely need a new node that can rotate around the given origin. The current rotation nodes are always rotate around the origin so you can do the rotation first, and then move the object to the desired position.
If you want to modifiy the rotation origin of the object you can move it so the desired rotation origin will be in the global origin. Now you can do the rotation and can move it back to it's original position.
I've created a new issue to make the extended rotation node available.
Viktor Kovacs
Hi Florian,
Thanks!
