Placing Object with desired Hotspot
At last, I can put my object on the floorplan and I can change some attribute of it
http://archicad-talk.graphisoft.com/viewtopic.php?p=182285#1
My object have many hotspot but now I can use only default hotspot to place it.
Are there any way the place object using another HOTSPOT. So I can rotate it correctly. And easy.
Thank you
12 Replies 12
vfrontiers
I know this is not what you're discussing, but is there some "developer" code that makes an object NOT respond to the hotspot that is EYEDROPPERED?
For example, I have an object in plan... I used to be able to EYEDROPPER the CENTER HOTSPOT and all subsequent placement would place by the center... This does not seem to happen anymore..
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
This has been reported - and I was about to report it again, as it has been a few years and still not fixed. Cannot remember if this "broke" in 12 or 13. But, it prevents using visual favorites properly, such as with the Detailer palettes.
But, yeah, wrong forum: this is a Working in ArchiCAD issue.
I upload this source code to you
http://www.porrapat.com/ArchiCAD_Add-On1.zip
To help me find the problem.
It's place object with the same location.
But I don't want it
I use API Devkit 14.2550 on WindowsXP Service Pack 2
Running on ArchiCAD 14 Demo. Using visual studio 2005 to compile
