DGSketcher
Legend
GDL: Object placement point reset
I am in the process of upgrading a Legacy project with updated objects. Due to the history of some of the projects it isn't possible to apply a Forward Migration script. What I am doing is select each object in turn in the model and in the Object Selection Settings use opt-cmd-clk to "inject" the old parameters. This is working as expected. The frustration is some of the placed legacy objects have changed their placement hotspot in the 2D preview and the updated objects move placing their origin at the previous placement hotspot. This would be easy to resolve in the 2D preview if the objects weren't so large the hotspots merge or I could zoom in to change the placement point.
I would like to know...
Is there is a way to reset the placement hotspot to the object origin in a placed object?
or counter the displacement caused by mismatched placement points?
or prevent selection of anything other than the origin point in the 2D Preview?
If I use GLOB_PREVIEW_MODE to hide all but the origin point in the 2D Preview would that force a placement point reset without displacing the original object?
runxel
Without trying if it helps: The first hotspot, that is defined in a script (!) becomes the insertion point, not the origin.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
DGSketcher
Legend
Thanks. I didn't know that, probably because I always build my objects from 0,0 & place a Hotspot for it.
