jc4d
Recursive parameter update
Hello,
I have set two different values for A by selecting the size via dropdown.
Parameters:
VALUES "cab_type", "Pysty", "Vaaka"
Master:
IF cab_type = "Pysty" THEN
	A = 1.55
ELSE
	A = 2.00
ENDIF
The issue is that no matter what option I choose from the dropdown, the value A in the Object Selection Settings it doesn't reflect the new value.
Is there a way to see the new value updated?
Juan.
1 Solution
You have only set the value of A - which will be used in al further calculations.
You also need to set the Parameter as well which is what the user sees.
	A = 1.55
ELSE
	A = 2.00
ENDIF
PARAMETERS A = A
Go to post
	A = 1.55
ELSE
	A = 2.00
ENDIF
PARAMETERS A = A
