GDL
Roof Window SEO body
Jochen Suehlo
If I work with 2 roofs above each other, because of the better handling on eaves, a roof window only cuts into the roof in which it was placed and not in the 2nd.
I now added a SEO body in the roof window to cut the hole into the second roof. For this I added a script part starting with "IF GLOB_SEO_TOOL_MODE THEN".
If I now place the roof window in the outer roof, go to section, select inner roof, go to SEO Palette and let it be the target, select the window and let it be the operator and execute the SEO command with "Subtract" nothing happens.
Question: Do the SEO commands not work with a Rooof window and a 2nd roof?
Jochen Suehlo . AC12-29 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
Most of my scripts are old so I have never used that command.
I use ...
if GLOB_CONTEXT > 40 and GLOB_CONTEXT < 50 then
I know it works for objects but I have not tried with doors, windows or skylights.
Maybe they are different, but don't see why.
Are you sure you have the SEO cutting body in the correct position?
i.e. on the correct side of the skylight and it is thick enough to pass through the other roof?
runxel
Hero
I think SEO never works between any type of openings (Wi/Do/Skyl) and something else. They are for me not even possible to add as an operator in the first place.
Great idea Jochen, but sadly not possible 😞
