GDL
[SOLVED] String length to pixel length? Like STW() in GDL
Erenford
Is there a DG function that computes for the length of the string in pixels? Something equivalent of STW(string) in GDL.
I'm trying to make a button that have a width according to its text. I could base it on the widest char like 'W' but it would be too wide for something like char 'i'.
Thanks.
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Hi Erenford,
You should use APIAny_GetTextLineLengthID goodie function for this.
Example code:
double	DetermineTextWidth (const char* str, short font, double size)
	if (strlen (str) == 0)
		return (0);
	API_TextLinePars	tlp;
	double				width = 0.0;
	BNZeroMemory (&tlp, sizeof (API_TextLinePars));
	tlp.drvScaleCorr = true;	// Apply drawing scale...
	tlp.index = 0;				// Get the length of the longest line (there may be only one line...)
	tlp.lineStr = const_cast<char*> (str);
	tlp.wFace = APIFace_Plain;
	tlp.wFont = font;
	tlp.wSize = size;
	tlp.wSlant = PI / 2.0;		// Plain text
	ACAPI_Goodies (APIAny_GetTextLineLengthID, &tlp, &width);
	return (width);
Regards,
Tibor
Erenford
oooh so there is one!
So for dialog box with default settings, I'm guessing no drawing style, with size 12. I'm not sure what the default font is so I just set 'wFont' to 1.
Seems it's working fine!
Thanks Tibor.
