GDL
Show Zone Stamp, Window & Door marker from MVO
JGoode
I'm trying to pull the information from the Construction Element Options for the "Show Zone Stamp" as well as door and window "with Marker". I just want to check whether they are toggled on or off. Is this possible? I tried looking at doing it through LibraryGlobal but they don't sit in the library in the same way, if at all.
Thanks
ArchiCAD 27
Windows 10
Peter Baksa
Hi JGoode,
REQUEST("WINDOW_SHOW_DIM", "", show)
REQUEST("DOOR_SHOW_DIM", "", show)
Returns 1 in the show variable if in the Model View Options > Window options the "with Markers" is checked, 0 otherwise.
Curtain Wall and Stair MVO options are in globals GLOB_MVO_...
Zone stamps, and most of non-library MVO settings are not available.
PƩter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
I think "DOOR_SHOW_DIM" etc are deprecated after AC19.
Cameron Hestler, Architect
Archicad 27 / Mac Studio M1 Max - 32 GB / LG24" Monitors / 14.5 Sonoma
Still works for me in 28.
In fact I just checked and I am using the old combined command.
nn = request ("window_door_show_dim", " ", show)
