GDL
populate property with parameter value
easyDoesIt
Hi All,
I saw some topics regarding populating a parameter with a property value but I was trying to figure out if its possible to populate a property with a parameter value.
I found the GDL manual not so helpful around this, does anyone have any ideas if and how this can be done.
Cheers, Mark
archibites.tech | Wet Area Tool | Door Circulation Compliance | Multi-Label | Roof Slope | Wall Type Label
Brisbane, Australia
Windows based system on all versions of Archicad
13 REPLIES 13
The installation of the add-on is performed in the standard way — either by copying the add-on file directly into the Archicad Add-Ons folder or by adding it through the Add-On Manager. The installation instructions are available at this link.
Industrial Architect and Structural Design Engineer, developer of free addon for sync GDL param and properties
Nice addon kuvbur.
Cheers, Mark
Brisbane, Australia
Thanks kuvbur.
I found your wiki page of course.
Unfortunately, my Russian is not very good, so that doesn't help much.
Don't you have an English description somewhere?
Gábor
Versions 6.5 to 28, AMD Ryzen 9 3900x, 32GB ram, GeForce RTX 2070 super, Windows 10
Sure, there is an English version of the command list.
