Creisner
Archicad 27 entering dimensions problems
So we updated to Archicad 27 and now when moving a guideline or anything such as a fill, we enter the dimension such as 45 1/8 and as soon as you type the / the number resets to empty.  Is anyone else having this issue?
5 Replies 5
Not experiencing (ARM Mac) - please list your OS so people  know if this is WIndows, Intel Mac or ARM Mac.
I'm guessing you're using a numeric keypad.  Does the same thing happen if you use the "/" on the main keyboard?  I'm guessing a keyboard setup issue.
Creisner
it happens on both, anytime you push the / the number disappears.  Using decimals everything works fine but thats not an ideal situation for us.  We have been using Archicad for over 10 years and this is the first time something like this has happened.  I just figured it was a bug in a setting on the new 27 version.
Creisner
one user is on a mac and the other 4 are on PC
Ricardo Heim
I think it's the new math function, every time you press the "/" it will divide by 2 the currently showing dimension, at least in the metric system it works that way
Yet it is working as it always has for me on 27 Apple ARM version... so hard to explain why it works for me and not @Creisner ... unless there is a Work Environment setting to enable the new math functionality that I missed?
