ephrem
Archicad 30 Light mode: where did the contrast go?
Hi everyone,
I’m testing Archicad 30 and I have a concern about the new interface, which I’d like to compare with your own experience.
Light mode: it is now far too bright, and readability has clearly suffered. In dialogs (Wall Selection Settings, Surfaces, Perspective Options, etc.), the value input fields are white on a white window background. They blend in and are barely visible. In Archicad 29, dialogs had a slightly greyed background, so the fields stood out clearly. That contrast is gone, and it makes scanning a dialog and locating the field to edit slower and more tiring.
Dark mode: it isn’t a satisfying alternative either. Many elements remain white (fields, panels, parts of dialogs), which creates a harsh and unpleasant contrast against the dark surfaces. The result feels inconsistent and not very ergonomic.
Questions for the community:
  1. Do you also find the Light mode too bright and low in contrast compared to version 29?
  2. Does the Dark mode’s remaining white elements bother you as well?
  3. Have you found any workaround (OS appearance settings, display calibration, etc.)?
Questions for the Graphisoft team:
  • Is a contrast correction of the Light mode interface planned (for example a slightly greyed dialog background, or visible borders on input fields)?
  • If so, is it targeted for an upcoming update of Archicad 30?
In its current state, the visual comfort is clearly lower than in version 29, especially for those of us spending the whole day in dialogs. I’ve attached screenshots to illustrate.
Thanks for your feedback!
Ephrem
Capture d’écran 2026-10-13 à 08.29.40.pngCapture d’écran 2026-10-13 à 08.20.01.pngCapture d’écran 2026-10-13 à 08.29.19.png
5 Replies 5
Andreas81ch
Mentor
Yes, I don't understand this change too..... it's to bright and bad contrast......
ArchiCAD v6.5 - 30 (CHE Swiss Edition / Schweiz) - macOS / WIN - Workstation in office: mac OS 26.5.1, Apple M2 Max, 64 GB RAM
laembert
I don't get why they changed it. What's the point of beta testing if they release this UX monstrosity?
Hi all,
Frankly I don’t see any change or downgrade to the light mode for Archicad 30.
I compared it with 29 version and it looks great, maybe it’s an issue related to your macOS.
Thanks.
AC 29 INT 4006/WIN 11
Maybe it is just a Mac issue as I didn't notice any difference in standard (light) mode in Window OS.
Dark mode in Windows is another matter and there are contrast issues that were mentioned in Beta.
Wlad222
Yes. This is THE worst implementation of dark mode I have ever seen. Have the devs even looked at a modern dark mode app? You cant just inverse colors haha...
