2026-08-04 08:18 AM - last edited an hour ago
Archicad是一款专为建筑师量身打造的真正面向未来的三维设计软件。然而,建筑、机电及其他各专业之间的跨学科协同整合,仍然是推动其在全行业普及应用的一大长期瓶颈。
这个项目源于一个长期存在的行业痛点:在Archicad中,建筑与机电专业的跨专业协同长期以来未能在各团队间得到广泛推广。随着人工智能的兴起,Blender、Rhino和Revit纷纷推出了基于MCP的自动化功能,这促使我利用业余时间开发了这款工具。尽管目前尚无法全面支持端到端的真实世界建筑项目,但它已证明是一项关键性突破:人工智能能够读取设计文件中存储的所有参数,并触发相应的软件操作。这一解决方案的全部技术潜能仍有待进一步挖掘,其关键在于大型语言模型的迭代演进以及未来功能的持续拓展。其核心宗旨在于为建筑师提供一条开放、实验性的技术路径,以探索人工智能赋能的设计。除作为一款独立的Archicad MCP连接器外,该工具还集成了两种运行模式——由AI驱动的智能工作流与手动指令控制——并配备了一个可扩展的平台,支持用户自定义扩展。 项目 MEPbridge ACAIstr 已开源,可在 GitHub 上下载,地址为https://github.com/bleufeng/mepbridge-acaistr
所用操作系统:Windows
2026-08-18 07:41 AM
v0.1.2 -Changed
Installation guides document the Node.js prerequisite, custom install paths, and a full step-by-step manual installation procedure covering administrator rights, locating the Archicad folder, choosing between Archicad 28 and 29, handling a previous build, and verifying the result.
The registered command and descriptor counts now come from a single ai-adapter/command-boundary.json file that the release gate, the public repository validator, CI, and the packaging scripts all read, instead of each carrying its own copy.
Command examples no longer contain hardcoded MEP system names or attribute indexes. Those identifiers are not stable across projects, locales, or Archicad versions, so omitting them lets the Add-On use the domain default. A static check keeps them out.
The Archicad runtime regression now checks returned content rather than only that response fields exist, and covers the favourite, layer-batch and classification write commands end to end, each restoring what it changed.
The internal command guide lists all 74 registered commands. It had 52, so the favourites, profile, view-map, classification and layer commands were absent along with the project and story queries. Command counts there now defer to ai-adapter/command-boundary.json.
The public repository validator no longer aborts on a Markdown link containing a stray percent sign; such a link is reported as broken instead.
2026-08-18 09:39 AM
claude is also working on this, what s the difference?
2026-08-21 06:10 AM
This refers to Claude Design? While Claude, GPT and Gemini already have their respective native MCP connections, they lack professional parsing for Archicad’s internal models. From an architectural‑specialty perspective, our goal is to add a dedicated BIM‑MCP vertical‑adaptation layer for Archicad, translate complex BIM model data into structured data readable by any large language model, and provide open, customizable extensions for any interface.
2026-08-23 07:26 AM
4 weeks ago
- Explicit wall heights are no longer clamped to the story height.
- Walls now use the center reference line; the body no longer shifts sideways.
- Window sill height is applied; openings above the host wall top are rejected.
- Windows and doors inherit the host wall's story.
- `set_active_story` previews by default and reports `previousStoryIndex`.
- Stair tread depth is reported as the effective `resolvedGoing`.
- Workbench template replay refreshes saved templates before execution.
- Fixed bug causing slow reproduction of user‑defined templates in Workbench.
- Moving and editing building elements by GUID with per-field masks and readback.
- Optional absolute-Z placement for walls, columns, objects, and lamps.
- Mirror and rotate accept explicit GUID lists.
- Four local server tools: list Archicad instances, capture/compare/replay snapshots.
- Copy is all-or-nothing with a single undo; delete is capped at 200 per call with `acknowledgeCount` above 50.
2 weeks ago
an hour ago
fix and capability release: rebuilt AC28/AC29 Add-Ons, corrected element move and roof geometry handling, and added create-with-properties, beam vertical placement, wall constraint and reference-line control, movable roofs, and clearer readback diagnostics across the Workbench Server and MCP tools.
