It is really simple.
1) Select wall tool, do a click where yo want to start (checkmark icon if you are snapping to an existing object or the origin)
2) move the mouse in the direction you want to go and press Shift to make orthogonal
3) Release the mouse, keep holding down the shift key
4) Press "R" and release Shift
5) Don't touch the mouse or the keyboard, take a break, and look at the info palette at the bottom of the screen, you will see some distance text highlighted.
6) Type the distance and press enter/return. Remember that AC is backwards than AutoCAD in that if you don't specify if it is inches/feet it will assume it is feet ( 1.5 in AC = 1'-6", in AuoCAD = 1.5")
7) if you want to change the angle type "A" and write it, press enter.
repeat as necessary
Eduardo RolĂłn AIA NCARB
AC29 US/INT -> AC08Mac Studio M4 Max 64GB ram, OS X 10.XX latest
another Moderator
