General discussions
Posts about job ads, news about competitions, events, learning resources, research, etc.
HP DesignJet T850 Printer
Zdenko
is there a way to add plotters not listed under the "file" "plot setup" routine?
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
4 REPLIES 4
Lee Hankins
Have you installed the drivers from HP’s website? We have the T850 and have it visible in the plotters list. We do have multiple options for Hewlett Packard so had to search through each one but it was there.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
hi lee - we saw the multiple options but no t850. tried to re-install the driver but it won't go past the "click-app" removal crap...for some reason it's keeps recognizing a design jet which doesn't exist. ill let you know what happens...
Sequoia 15.1.1
DylanCruz
I am facing a problem, should I ask it here?
If it is about using a Designjet T850 printer with Archicad, then yes.
