General discussions
Posts about job ads, news about competitions, events, learning resources, research, etc.
Indesign/Archicad Icons
KeesW
I have installed the Adobe Creative Suite on the same drive (drive C) but separate subdirectory and folders, as Archicad and have got a very nasty surprise. All of my archicad PLN files on my hard disk, accumulated over many years, have changed to Indesign files and cannot be opened in Archicad. Does anyone have any suggestions? I will try to remove InDesign to se if this reverses the problem.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
No need to panic or uninstall 😉 (it won't do much unless you also run System Restore to restore your registry to where it was before the installation).
The problem sounds like InDesign has taken over the PLN extension.
You can still open these files in AC by starting AC first, and then using File Open to open the files.
But, here are a couple of methods to get the file association back to AC:
1. Easiest: Browse in Explorer to a folder containing AC PLN files. Right-mouse one, click Open With... and then - even if you see AC (!) - select "Choose Program...". NOW, select ArchiCAD (or browse if necessary), and be sure to put a check mark in the box "Always use the selected program to open this kind of file". Then click OK. Exit AC after it opens. You've reset the 'open' behavior for PLN files in the registry.
2. Tricker/easier to screw up: In Explorer, Click Tools | Folder Options, then the File Types tab. Set the appropriate info for PLN (perhaps by copying it from BPN).
One of the forum moderators
KeesW
Thanks for that. It worked!
What a useful list this is!
You're welcome ... glad it worked! 😉
Karkl
