tokaamer
MSc Dissertation Survey
Hi there!
I would appreciate it if you can help an MSc student out with her dissertation research by taking this 10-15 minute survey! This survey seeks the valuable input of Architecture, Engineering and Construction (AEC) stakeholders on projects, specifically those with knowledge of Building Information Modelling (BIM) and Digital built Environments.
Link to Survey: https://forms.gle/8pRF8yJXaQC98ZYUA
To answer this survey: You need NOT have worked on a BIM-enabled project, but you DO need to have an understanding of BIM, its requirements, potential/ reported benefits, standards and workflow.
Feel free to directly contact the researcher (student) at the email provided for any questions / constructive comments or clarifications.
If you know someone who knows someone, feel free to spread it around. Thank you!
2 Replies 2
Rubia Torres
Hi @tokaamer,
Thanks for sharing. I kindly left my contribution.
Best of luck to your friend.
Rubia Torres
Community Expert | GRAPHISOFT SE
Did you get a helpful answer on the forum?
Give it back to the Community by marking it as an accepted solution!
tokaamer
Hi Rubia, Thank you!! Much appreciated. 🙏
