General discussions
Posts about job ads, news about competitions, events, learning resources, research, etc.
!Restored: opening multiple files on the Mac
hello, I would like to be able to open several pln files at once. I do not seem to be able to do it on my mac yet my pc compadres do it with ease. I have achieved it by copying the program and launching the program multiple times, but this eats memory. Can I open multiple plns under one program?
9 REPLIES 9
No
__archiben
Millard wrote:
No
so there. ( )
but i've never really had too much of an issue with multiple versions of archiCAD 'eating' the memory. when the other versions are idle, OSX handles their memory/processor allocation and drops them right down close to zero. what are you getting? (fire up your multiple versions and then open the 'terminal' application. type "top" and hit return . . .)
i'd be interested to know. (it would also be handy to know your computer/archiCAD specifications as well. put them in your signature file?)
cheers!
~/archiben
b e n f r o s t
Ralph Wessel
Mentor
~/archiben wrote:
...open the 'terminal' application. type "top" and hit return . . .)
There is a GUI front-end for this called 'Activity Monitor' in the 'Applications/Utilities' folder. I think most users are a bit wary of the command-line interface in Terminal.
Ralph Wessel BArch
Active Thread Ltd
__archiben
yeah - and you end up looking like a right geek in front of your colleagues if you use the terminal
go with ralph's suggestion!
~/archiben
b e n f r o s t
You can.
Make a copy of the application BG ArchiCAD and rename it something else like BAD ArchiCAD. You can open as many individually named replications of BG ArchiCAD to view multiple files simultaneously.
Keep BG ArchiCAD for use only by Plotmaker.
What is/are the step(s) necessary to move from Demo mode to "Full" mode.
ArchiCAD 9.0
Thanks...
__archiben
as you can with the main archiCAD application. however:
. . . but unfortunately, no you can't open multiple PLNs under one program. (see above!)
~/archiben
b e n f r o s t
__archiben
answered here: http://archicad-talk.graphisoft.com/viewtopic.php?p=37741#37741
~/archiben
b e n f r o s t
Djordje
ArchiCAD 9.0
Plug your protection key in.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
