Where are the new project set???
   Hi Zaid,
Thank you for informing us about the new look of that page but are you kidding about the new project samples set, I can’t see any new project, all those mentioned in the page are so old.
Can't you acquire any new project from any firm is using Archicad? As the Spanish one called (Morph) or any other firm we read about their real cases via Graphisoft’s social channels.
AC 29 INT 4006/WIN 11
4 Replies 4
Guru
Be optomistic and hope that they just forgot to push the update to repopulate that page...?
I hope for a real update.
Yasmin Herden
Hi @Mahmoud Qenawi
Thank you for your feedback.
The aim of the Sample Projects is to provide high-quality examples of Archicad usage and file organization. Although the project set was not expanded, the files have been updated to incorporate new features and workflows to explore, such as Design Options, complete MEP systems, and the updated Global Library. These features were not available in the previous versions of the files.
Hope this clarifies what we aimed to communicate with our announcement, and we appreciate you taking the time to share your thoughts.
Yasmin Herden
Manager, Learning Services Content Lab
Hi Yasmin,
Thank you so much for your valuable interaction.
I really checked all samples and found they’re so helpful but noticed that they don’t reflect the full power of Archicad features, also the samples quality is not as before.
At all, I can’t ignore the efforts put for updating those samples, I recommend the update should continue for a less file size (see the below attached shot) and for an expanded set of new project samples.
