2022-08-22 04:54 PM - edited 2022-12-06 01:12 PM
Archicad is regularly updated with valuable fixes: you can enable the automatic Check for Updates to alert you whenever a library or program update is available. With the latest release of Archicad 26, all users have a new option: you can Check for Update Previews as well.
What is an Update Preview?
A few weeks before a regular Archicad update, Graphisoft releases a preview version. Update previews are internally tested but not yet ready for wide release. Now, any user can install and test the Update Preview, and report any issues or bugs, so they can be fixed before the regular update is released. Please use it at your own risk.
Set this preference (Check for Updates Only or Check for both Updates and Update Previews) during installation. You can change your notification preferences at any time in Archicad’s Work Environment dialog.
What's new in the Archicad 26 Update 2 Preview?
As usual, the focus of Archicad updates is to improve the existing release based on users’ feedback and bug reporting. This time is no exception and our teams have worked hard to deliver an even better solution for you. Get more detailed information regarding bug fixing on the regularly issued List of Improvements.
Archicad 26 Update 2 will also introduce some new functionalities and enhancements, such as:
Archicad 26 Update 2 Preview will be available starting August 26 (you will get notified automatically once the update is available) in the following languages: INT, USA, UKI, AUS, NZE, GER and AUT.
Product Success Team
