on
2025-05-22
11:18 AM
2026-03-13
10:10 AM
Andrea Polgar
Dear Community,
This month’s tip comes from a discussion in the Documentation forum. @NateLumen asked if it’s possible to name multi-page PDFs using Autotext. This is helpful when you’re exporting multiple document sets and want organized, date-stamped filenames without having to rename them manually.
Thanks to @Barry Kelly and @MitchD, we share a simple and effective workflow below using built-in Autotext features in Archicad Publisher.
Note: You won’t be able to pick from a dropdown, just type the tags directly.
Rename the folder using AutoText keywords
You can customize the output name however you want using Autotext fields like <PROJECTNAME>, <PROJECT_DESCRIPTION>, or <SHORTDATE>.
To control what these values display:
@Barry Kelly also shared the LINK to find other Autotext commands with us.
This gives you full control over how your PDFs or folders are named and makes the output consistent across exports.
Customizing Autotext fields and find them in Project info
Publish with a merged PDF file
When you publish, the final merged PDF will automatically use the Autotext as its filename.
This method works because shortcuts retain metadata from the Layout Book, which Autotext can reference, while regular folders don’t.
@Barry Kelly also pointed out a different method, if you want o publish all the layouts into one folder and not as a single PDF file; by using the "Real folder structure" option:
Note: You can name each file using Autotext, but by default, the folder (subset) name won’t show up in the PDF filename.
This works well if your workflow needs individual PDFs organized by folders, rather than one merged document.
When using the “Merge into one PDF” option, the exported file takes on the Autotext-based name you set – such as project date, name, or description, resulting in a clean, consistently named PDF output.
Publish files as a merged PDF
If you choose to publish using the Real Folder Structure, each folder is named using Autotext as defined.
Publish files using Real Folder Structure
Thanks to @MitchD for confirming this method works, and to @Barry Kelly for the key detail about typing Autotext manually. Click here if you want to look at the forum discussion.
Also, shoutout to our honorable mention about extracting coordinates from a DWG file with no attributes, just linework. It offers a smart workaround without using external tools.
If you’ve got your own trick or tip, don’t hesitate to share it on the Community, it could be featured in our series next month!
Cheers 🎉
