2026-08-26 11:03 AM
Join Graphisoft and Finch experts for a walkthrough of how Archicad and Finch work together across the design process, from early massing to compliant BIM documentation.
Early massing and documentation in Archicad
Firas Omezzine, BIM engineer at Graphisoft, will open the session with an introduction to Graphisoft and the Archicad design environment. |
Finch + Archicad workflow demo |
Jesper Wallgren, CPO and Co-founder at Finch, will walk through the combined workflow: starting with an Archicad mass model, moving it into Finch, generating compliant floorplans, and downloading the resulting BIM model back into Archicad. |
| Customer case study
Nikola Ž. Umićević will share their experience taking a project from concept to BIM using Archicad and Finch together. |
Live Q&A |
During the live Q&A session, our experts will answer your questions and dive deeper into the topics covered in the webinar. This interactive segment is your chance to get scenario-specific insights directly from the presenters. |
Jesper Wallgren, Finch CPO and Co-founder Jesper Wallgren is a Swedish architect and computational designer focused on the future of AI-assisted design. As Co-Founder and CPO of Finch, he leads the development of generative tools that use graph neural networks to create adaptive floor plans based on context, constraints, and performance goals. Jesper’s work explores how architects can collaborate with intelligent systems to unlock better decisions earlier in the process. Known for his clear visualizations and human-centered approach, he advocates for tools that enhance, rather than replace, architectural creativity and intuition.
Firas Omezzine Architect and BIM engineer Firas is a qualified architect and BIM Engineer specializing in digital transformation and Open BIM workflows for the AECO industry. At Graphisoft, he helps architecture, engineering, and construction professionals optimize their workflows through strategic consulting, technical demonstrations, and solution implementation, enabling organizations to maximize the value of their digital processes.
Nikola Ž. UMIĆEVIĆ Lead architect / Deputy Head of Design Unit, Bureau Cube Partners Nikola Ž. Umićević is a Serbian architect and design leader with over 10 years of experience across Slovenia, Greece, Qatar, and Serbia. As Deputy Head of the Design Unit and Lead Architect at Bureau Cube Partners, he oversees complex architectural developments, guiding concept design and project coordination from early ideas through to high-quality, sustainable execution. Holding a Master of Architecture, his work spans high-end residential, commercial, and mixed-use developments. Known for pairing digital fluency in Archicad, Rhino, and Grasshopper with strong cross-cultural collaboration, he embraces parametric, data-driven design to sharpen both creativity and technical precision on every project.
Tune in for a look at how Archicad and Finch combine to speed up early design decisions and keep them connected to your BIM model.
Even if you can’t attend live, register anyway — we’ll send you a link to the recording afterward!
📌 After registering, you’ll receive an email with a calendar invitation.
📌 Please add the invitation to your calendar to check the webinar start time in your time zone.
📌 After the webinar, you’ll receive a Certificate of Attendance (PDF).
📌 The webinar will be held in English.
📌 The live Q&A session will not be included in the replay.
