Do you mean
Do you mean
Graphisoft Graphisoft Graphisoft
Wishlist Spring clean-up is wrapped - here’s what’s next!
8 Comments
Hi, @Rob
please we need new modeling capability, example a NURBS tool, openings in shell tool, more modeling method with shell tool "more than two polygon profile planes", method with crossed profiles, today our modeling capabilities are not at market level
I don't think it's difficult for graphisoft to give the possibility to draw a shell in elevation and section like with the curtain wall, we want more new possibility to free the tools please
Thanks
Ace
Just a revamp of the dimension tool, both for levels and dimensions, which should be model and criteria dependent, instead of click dependent. Current state of things is what causes the biggest bottlenecks and delays for us.
I'm just going to say one thing...
RAMPS
Opening
1_selects an opening edge and changes its surface
2_using a complex profile as an opening shape would allow us to no longer use posts and beams as negatives to sculpt facades (people do not prefer to use niches) because the geometry is limiting
Curtain wall
overcome the limits of the software which lasts too long, for example
the possibility of modifying the surface of a personalized panel of a curtain wall
possibility of drawing a conical curtain wall simply without going through manual assembly techniques as with the shell tool and there are lots of other things left
To put it simply, we want a homogenization of drawing methods between the different tools, example curtain wall and the shell tool.
Guys, please note that the comments section is for discussing the contents of the post (the wishlist itself and its developments), not for posting new wishlist items. If you guys post wishes in this thread, they will not be processed as this is not the proper place for that. Please wait until the wishlist functionality is available again and then post your individual wishes in separate threads so they can be voted on and properly processed.
Hi' @Laszlo Nagy
I can't delete my comments, is there a way to do it?
@abdelaziz
We can keep them here as reference for future commenters.
Share:
