Friday - last edited Friday by Barry Kelly
Has anyone noticed the resolution of some of the AC28 library parts for some objects in 3D has something going on with it? I loaded the 27 library and also pasted from AC27. AC28 is doing something to them.
See attached image of what I have found so far...
Solved! Go to Solution.
Friday
Check your Model View Options.
You probably have 'Simplified' or 'Schematic' set for your 3D object presentation.
Friday
Friday
thanks! It was the MVO. The objects that had higher resolution were set to full. Some of the objects though are set to rather low resolution by default it appears
