Expanded version support (BIMcloud SaaS with cloud license)
BIMcloud SaaS with cloud licenses now works with all supported Archicad and DDScad versions. Turn on Legacy authentication method to enable BIMcloud to connect to older versions of Archicad and DDScad.
Compatibility with macOS 15 (BIMcloud on-premises - Q3 2024)
BIMcloud will be compatible with the newest macOS with Rosetta.
Optimized BIMcloud performance (Q3 2024)
We’ve revamped a component that speeds up access control processes. You’ll notice a significant performance improvement, especially when many users start Teamworking at the same time (e.g. Monday mornings), or after changes in folder structure.
Information security for BIMcloud
Rest assured that your BIMcloud data remains secure. Graphisoft will be certified against ISO 27001 this year.
The ISO 27001 is the leading global standard for information security management - and the most significant cyber security certification.
