2024-07-17 09:14 AM
I have been trying to use distance guides to my advantage, but unable to do so as they are not working as shown in the webinar. Main issue is the DG arrowheads are not sticking to new references when manually guided.
2024-07-17 12:44 PM
Hi @SSharma
As a Windows user I couldn't reproduce that bug & DGs are working smoothly, if someone else with Mac system may approve it.
2024-07-17 02:11 PM
I had a similar issue but it was because the walls are not perfectly parallel to each-other.
2024-07-17 02:20 PM
I have checked for parallelity. Also, the dimensioning is working, so walls must be parallel. I think, there is another issue, but will check again. Thanks.
2024-07-17 05:25 PM
No problem for me as a Windows user as well.
It worked as expected.
2024-07-17 07:17 PM
I have checked. If I am opening an AC27 file (made with educational version) in AC28 tech prev, then the DG is not working fine. But, if I start a project from scratch in AC28 tech prev, then it's working fine... So, may be a problem with educational projects made in earlier versions, as licensing is also an issue with them (can be opened through a workaround of opening a blank file of AC28 first).
