2024-07-16 07:32 PM
I can't hide Point Cloud in 3D view through "Hide selections" in Technology preview.
When I use this button, Point Cloud is still visible and in Layers setting that layer is hidden.
Is anyone experiencing the same?
Solved! Go to Solution.
2024-07-17 04:41 AM
It seems there is a problem where the Quick Layers palette does not work in the 3D window.
2024-07-17 04:41 AM
2024-07-17 05:23 AM
Yes Barry is correct plus there is a new hide selection command if you are using the AC27 version
2024-07-17 12:41 PM
Hi, thank you. Yes it’s the same but in my case just with layers where is Point Cloud.
