2024-07-23 11:12 AM
Where can I get a hold of the Library Developer Toolkit for version 28?
It is not in the Tech Preview downloads and the developers website only has up to version 27.
I am attempting to change the default parameters of the Global library Packages to suit my template, but it appears I need the Lib Dev Kit.
2024-08-09 11:27 PM
@Magdolna Marosvari wrote:Yes, we agree that a user friendly tool is much needed to set library defaults. Internally we refer to it as Unmapping Values development which we are hoping to deliver next year.
Good to hear, the sooner the better. Hopefully this tool can be used to edit any JSONs used by Archicad. I am also happy to hear new library developer documentation is on the way. All of this is new and quite complex so I hope these new resources will cover everything discussed here and more.
For example this is the first I have heard of Pathname Tables even though I have been following the Global Library development since the beginning.
And from your previous post I learn there are Mapping Definitions contained in each libpack, in addition to the Mapping Value Tables connected to files or templates. I presume those two interact but I'm not sure how.
Regarding the folder structure: Yes, the folder structure depends on the template, the path name table defines is.
You can find the pathname table files in the Localization folder of an extracted library package. (For extraction see previous reply).
But before we dwell into these details: Have you tried the Folder View with Source view in the Tool Settings to set up custom folder structure?
Folder View (with sources) seems to reveal the libpacks themselves and whatever folders contain them, so everything upstream, but not how the objects are organized within the libpacks. Please correct me if I'm wrong.
What do you wish to accomplish?
My goal is twofold:
I hope this is all possible with the new system and that maintaining the customizations will be relatively easy. I am taking my time figure all this out, and let the more eager among us lead the way, especially while current projects finish up with the old monolith libraries.
2024-08-12 01:25 PM
Hi @SeaGeoff ,
The goal of the tool wouldn't be JSON editing but to provide proper Archicad UI to set default values. What other JSON would you like to edit by the way?
Yes, Pathname Table and Mapping Definitions and their connection to Mapping Value Table will be covered in the documentation too.
You are correct, 'Folder View (with sources)' is about organising library packages in different folders and the Pathname Table is about how the objects organised within the library packages.
My goal is twofold:
- Change the Global Library defaults to match my template attributes, which like Barry's are quite different from the Graphisoft templates.
- Combine my custom objects and the Global Library objects in a single folder structure. I'm not yet sure whether I will match INT, or USA, or create a new one.
Yes, your goals are feasible with the Global Library. You can even create multiple alternatives, USA, INT or custom structure setups and decide from Archicad which one to use at each project start.
Best regards,
Magdolna
2024-08-12 01:42 PM - edited 2024-08-12 01:49 PM
Hi @Barry Kelly ,
Yes, until now 2D symbol appearance was adjusted to GS templates. Now that the Mapping Value provides the possibility to flexibly adjust the library defaults it makes sense to make these attributes adjustable too by users.
What can be expected that you set it up for yourself now and likely from Archicad 29 it will be handled on exe side.
Best regards,
Magdolna
2024-08-12 08:32 PM
Hello @Magdolna Marosvari, I really appreciate your thorough replies. I am eager for the detailed documentation, and of course a proper UI for setting the defaults will be amazing. So there's a lot to look forward to but it also seems patience is warranted while all the pieces fall into place. In the meantime I hope you can answer a few more questions to help me formulate an overall strategy.
Thanks again.
2024-08-13 05:27 PM
Hi Barry,
The mapping value table maps meanings identified by an unique string/type combination to a value. This is stored in the plan file.
Meanings are stored in each libpack, in a file mappingDefinitions.json. This part maps libpart/parameter combinations to meanings.
The hidden parameters which are not in mappingDefinitions.json but editable on the UI can be considered a bug. To define a mapping value for them, first a meaning has to be created, which can only be done by modifying the .libpack file.
Maybe an easier solution could be creating a favorite?
2024-08-13 05:44 PM
Looking at the object more closely, these parameters are not on the UI, but already have a meaning.
Now I see the problem, it is that not all meanings are included in each template.
Until the more flexible tooling arrives, in such a case check mappingDefinitions.json in the libpack for the actual meaning name.
Here they are:
gs_fill_type -> gs_fill_type8565
gs_fill_pen -> Street_FillPen
gs_back_pen -> Street_BackPen
2024-08-13 06:10 PM
Hi Geoff,
VSCode can handle it.
Excel can have 1Grows, it should be possible to import as Data with Power Query.
.libpacks contain pathNameTables, which define a virtual folder structure. package.info/LocDataPath defines which table is used for which localization. File/foldername dictionaries are applied to the virtual names for translation. This way many localizations can use the same pathnametable structure and display it in their own language.
2024-08-14 08:05 PM - edited 2024-08-14 08:22 PM
Hi @Peter Baksa, thanks for the details. The system components are starting to make sense but I think we will all benefit from a map or diagram of how this all fits together. Hopefully that will be part of the upcoming documentation.
To clarify, we will need to package our custom libraries in libpacks that include these complimentary files if we want them to conform to the same template-based control we can now impose on the global library. Is that correct?
Additionally, I tend to edit my custom objects on a regular basis. Since my office library is small I do not create LCFs, which in turn makes these modifications easy. Is it possible to directly open and edit the GDL of objects inside libpacks?
I'm in search of the holy grail where we can set the defaults for the global library to match our standards AND include our custom objects in the same virtual folders AND preserve the power to edit the GDL of our objects directly without cumbersome extraction and repackaging. Please tell me this is possible. Thanks.
2024-08-26 11:09 AM
Hi Geoff,
if your office uses only one of the available localizations, the GSMs can be placed in the same folder structure as the virtual, and they will be merged.
2024-09-05 12:05 AM
Thanks @Peter Baksa, I will try that. To clarify, I can load a single folder containing other folders with GSMs (no need to create LCFs or libpacks) and, if I match the virtual folder hierarchy of the libpacks I have also loaded, my objects will be merged into that virtual folder structure. Is that correct? Does my top level folder (the one I will add with the Library Manager) disappear in this workflow, or do I need to name it something specific?
