2024-06-05 10:08 AM - edited 2024-06-10 02:59 PM
MEP Designer introduces a comprehensive MEP workflow into Archicad, It’s a better way to design, coordinate, and collaborate on MEP projects - for both architects and MEP engineers.
Fully integrated into Archicad 28, architects and MEP engineers can collaborate easily on the same platform via Teamwork. And MEP Designer is easy to learn and use - with specialized tools and objects that automate and simplify MEP design and editing.
Make sure your MEP model element sizes are compatible with products available on the market. With expanded Route Specifications, it’s easy to place MEP elements in preferred sizes.
Use a predefined reference set of dimension data for ducts and pipes, or create your own. Then define tables of dimensions for segments, elbows, and branches, using dimensions that match the MEP elements you need. Your presets are now at your fingertips, at all levels of MEP elements.
Route Specifications in Archicad 28 (replacing Route Preferences) include
More detailed segment specification (DN diameter, inner diameter, description)
Setup options for predefined bends and branches (T-elements)
Calculate and resize preplanned ventilation systems at early design stages. Monitor velocity values to help manage sound emissions and keep energy costs low
MEP System Browser calculates air volume flow and velocity on each route in the system, using the given dimensions
Automatically updated system dialog provides runtime calculation and displays relevant calculation information in table form
Easy-to-read hierarchical tree, plus sortable flat list view
Calculating air volume flow requires the right connections between routes and other components. Switch on “Open MEP Connections” (View > On-Screen View Options) to mark all connection mistakes in the plan. This lets you find and fix them easily.
When you connect a route element to a standalone MEP object: the route element automatically “inherits” the object’s MEP System and Connection type, saving you the work of editing route settings.
Resize routes or entire systems with Duct Optimizer - based on user-defined limits, such as dimensions and velocity
In the model: select any segment to edit its dimensions (no Edit mode needed)
Logical, story-based display and documentation of MEP route elements, thanks to new display settings:
More accurate and intuitive modeling: input and edit your MEP systems in section and elevation views too
Place MEP routes with precise geometry, thanks to customizable alignment and offset settings for route segments.
For example, to place a duct closer to a slab, realign route reference line to the top point. Or define an offset to keep a route at a certain distance from a wall or ceiling.
Customize alignment or offset for any segment in Edit mode
Further expansion of your MEP toolkit
Manifold objects
Enhanced radiators
Duct and Pipe Supports
Flexible Pipe tool
Take-off
