Say goodbye to manual audits and hello to effortless decision making!
The Project Migration Audit Tool takes the guesswork out of migrating your project. This easy-to-use add-on checks your existing project and tells you what will happen if you migrate it to the latest Archicad. A color-coded itemized list helps you see the result and plan for any needed adjustments.
Expected release: Q4 2024
