Your favorite parametric design connection now has expanded modeling features such as:
Improved Design with Columns and Beams
![TariqueKatuntu_1-1721123986063.png TariqueKatuntu_1-1721123986063.png](/t5/image/serverpage/image-id/66241i1F4688F9626FF1FB/image-size/large?v=v2&px=999)
By using the Beam/Column Sorter located in the Archicad Utility Components, you can sort curves into suitable inputs for either Beams or Columns based on a degree rule.
![TariqueKatuntu_0-1721122764914.png TariqueKatuntu_0-1721122764914.png](/t5/image/serverpage/image-id/66239iB33D2C5B9E690DC8/image-size/large?v=v2&px=999)
This enables you to model unique shapes, thanks to expanded Beam and Column options such as:
- End cuts
- Vertical curves
- Circular beams
- Reference axis setting in both Beams and Columns
- Axis rotation setting in both Beams and Columns
Save time on Beam/Column input since Grasshopper sorts your elements into either Columns or Beams based on element slant.
Built-in support for Hotlink Modules
![TariqueKatuntu_0-1721123973699.png TariqueKatuntu_0-1721123973699.png](/t5/image/serverpage/image-id/66240i98BA3FB6506D5625/image-size/large?v=v2&px=999)
You can now place hotlink modules from Grasshopper to support ideation on any scale.
This enables you to:
- Place, move, and distribute hotlinks
- Update hotlinks and modify hotlink settings
Hotlink Component
By using a Hotlink Component, you can generate a hotlink instance of a selected Hotlink Module.
![TariqueKatuntu_0-1721119440779.png TariqueKatuntu_0-1721119440779.png](/t5/image/serverpage/image-id/66236iCE03CB4D7492799F/image-size/large?v=v2&px=999)
Hotlink Module Input Component
Use the Hotlink Module Input Component to set a previously saved module.
![TariqueKatuntu_1-1721120346671.png TariqueKatuntu_1-1721120346671.png](/t5/image/serverpage/image-id/66237i4F08FF6AF9C031E9/image-size/large?v=v2&px=999)
Note: You can select .mod and .pln files from your computer.
After selecting a Hotlink source file, you can select which Story of the Source Project should be placed as a Hotlink. You can then match these selected stories to the ones in the Host Project.
Support for Rhino 8
Grasshopper Connection supports Rhino 8 as well as Rhino 7.
