2024-07-26 10:09 PM
If we want to use the SAF workflow, we need to model the carpentry structure with a beam tool.
A frequent connection will generate a completely meaningless collapse.
As long as only two beams meet it is fine.
It would be best if RoofMaker could build the carpentry from column/beam elements.
2024-07-27 10:05 AM
So frustrating you could be there for ages trying to reconcile things like this. I usually cut them a bit short so the won't intersect and create this ugly thing. Surely the developers know about this because this was an issue over a decade(sl ago.
2024-07-27 02:36 PM
Hello: yes it is annoying, however, that can be solved by reducing the order of the joints in the configuration to one of the beams
2024-07-28 07:53 AM
I encounter the same issues with the SAF file, particularly when exporting trusses for structural design. The SAF file cannot be generated due to joint-related problems. Graphisoft should implement a more straightforward solution to address this issue, rather than relying on complex workarounds that ultimately fail to meet user needs. While I doubt there will be any immediate changes, I believe the problem will be resolved once Graphisoft fully integrates a steel connections tool into the SAF file functionality. Until then, we are left to handle these tasks manually.
2024-07-28 09:09 AM
Hi!
This does not work.
Otherwise, in a carpentry workshop, there are a million connections to clean up.
2024-07-28 01:04 PM
There’s an integration between Allplan & Mitek Pamir for wood design & construction software, why Archicad doesn’t integrate and make partnerships like Allplan?
2024-07-29 05:57 AM
Put rafters to Layer Rafters and beams to layer Beams and make sure Layer Rafters have priority 2 and beams 1
They will never do the funny connection again
2024-07-29 07:19 AM
Separate layers with different intersection group numbers does work.
But if you want the bottom of the rafters to trim over the ridge beam, you will have to do a Solid Element operation.
2024-07-30 02:02 PM
Roofs made by roofmaker can be cleared with seo. Then export a .obj file and analyse in altar simsolid. There you define materials of elements and the software finds touch surfaces automatically. This would the best approach inside archicad. A mesh free method inside Archicad would absolutely unify architecture and structural analysis and design.
2024-07-30 08:40 PM
Beams are driving me crazy! This intersection automation is horrible when you have to deal with complex beam structures. Layer group numbers are not really a solution, because this leads to more layers with different group numbers only for beams - and a lot of layer management.
the better way would be a beam management inside the element - or sketchup-style groups.
