2024-08-14 08:38 PM
I am proposing an expansion of the Favorites functionality to include groups of elements as a "favorite cluster." This would allow users to save and quickly access predefined sets of elements that are frequently used together.
Example of a favorites cluster would be:
2024-08-15 04:28 AM
If you don't want to edit them (i.e. will always be the same arrangement), you could save a selection as an object and then just place that one object.
If you do need to edit it, then save as a module (.MOD file).
2024-08-15 02:02 PM
The cluster would be an editable arrangement. Yes the mods exist however performance wise they can bog down in a file and you have to know where to find them leading to a discoverability issue. Using a cluster that can be previewed natively in 2D and 3D within the favorites pallet and the ease of pulling an instance of it into project, would make it simple to create standard arrangements and reduce the number of pallets you would have to have open.
