Graphisoft Technology Preview Program 2024
SOLVED!
Window Treatments issues
Nelthompho
The window treatments such as window blinds, curtains and shadow helps us vitualise the model without client seeing what is inside, hence i tend to use reflective window material to hide objects such as funitures, plumblic fixtures and other objects in the model. In my imagination i though Archicad 28 will have window treatments in it, its a nice feature please add in or design addon to solve the issue. Cant be modeling in place every day. Assist us
2 ACCEPTED SOLUTIONS
Solution
There are curtain and blind objects if you want to take the time to place them.
Or just turn transparency off in your elevation settings.
In the 3D window styles, you can also control transparency.
For renders, use a glass material that is not transparent or you can turn it off in the render settings.
Solution
Hi @Nelthompho,
In addition to Barry's suggestion,
you can use these 2 sorts of glass material for your window's surface configuration, I hope that helps.
AC 27 INT 5060/WIN 11
2 REPLIES 2
Solution
Solution
Hi @Nelthompho,
