Installation & update
2D script problems
i've recently received a warning from one of my archicad files. it reads: "Polygon degenerated in line 104 in 2D script of file da_leaf_2D.gsm". it pops up whenever i zoom in or out. what is this and how can i fix it so that i may get back to work. i hope someone can help me.
I suspect you have adjusted the parameters of one of the doors(?) in such a way that it is now an invalid or impossible shape. Check you haven't set a dimension of a component to 0.000 for example.
To locate which object is incorrect, try deleting each door/window individually (and then undoing) until the error message stops.
It is also worth checking you have the most up to date library too.
It may be useful in future to put your ArchiCAD version and OS on your signature, as advice can differ for each version.
I TRIED WHAT YOU SAID AND IT WORKED. THERE WAS ONE DOOR THAT WAS ACTING GOOFY IN THE FILE. I JUST ERASED IT AND INSERTED A NEW ONE. PROBLEM SOLVED. THANKS A MILLION.
