AC 10.966 crash / modifying pens and colors
AC10 crash on Mac when applying the "Store as" command.
No warning, no bug reporter.
First occasionally, now each attempt. Seems to happen in all kind of drawings, even when starting from scratch with the AC10 template.
Do I need a re-install or is this a familiar problem ?
3 Replies 3
We seem to be having a similar problem. Did you ever find the answer?
I experienced a wedge (not to be confused with a wedgie), rather than a crash, in 987 when doing that this week, but was unable to reproduce it to file a bug report. The Pens dialog (and AC) both locked up with 'not responding' (XP Pro) and had to be forcefully closed.
Obviously we were wrong first removing all the pre-defined pen sets (except ArchiCAD 9) and replacing them.
When starting the AC10 template and "adding" our own pen sets, everything works fine.
We removed the layouts as well because we prefer clean documents to start with. No problems to report over there...
