Installation & update
AC 22, 4k Screen, Windows 10, Cursor very small
Hi there,
the Archicad cursor is insanely small on my 4k screen.
I found a way how to fix the problem in the Graphisoft Help center.
https://helpcenter.graphisoft.com/knowledgebase/74887/
But the Cursor becomes small again after each PC reboot.
Is there a solution to this Problem, so i don't have to redo the procedure again each time?
Thanks.
Did no one had a similar problem?
I used to have this problem all the time. But recently, it seems to have fixed itself permanently. I don't know if it was a Windows update or an AC update, but it seems to be stable now. You might try updating your Windows system and AC to the latest versions. BTW, the value of that registry item that seems to work for me is zero.
Richard
AC26 (since AC6.0), Win10
