AC crashed after after launch
My problem happened suddenly after I deleted unused programs on my computer. When I lauch AC 10 it brings up the intro image and then goes to debugger. When I exit then program crashes and nothing happens after that. I have also reinstalled the program several times but nothing helps. I run AC 10 on xp desktop. I must also say that I have just replaced my monitor with a HD but AC did run and then I got this problem
3 Replies 3
You give us little to work with. Did you uninstall ArchiCAD before the reinstall?
Oh yes I did uninstall first but somehow I think I have a problem with Java
Problem finally solved after I reinstalled quicktime. Apparently the quicktime I had was corrupt possibly due to a corupt update. Not always the best thing to go for updates
