We value your input!
Installation & update
AC12 : Error "Hide ArchiCAD" on OSX 10.5.4
Hide button in Finder does not work properly.
First attempts without succes. Finally ArchiCAD disappears (yes!) but can't be activated again :
- ArchiCAD file is still in dock / no access
- stop button doesn't work
- no force quit available
Any ideas?
16 REPLIES 16
SeaGeoff
Ace
I’m only running ArchiCAD 11 at the moment. But Joeri’s description matches mine, so it’s not a PPC issue.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-28, M1 Mac, OS 15.x
Graphisoft Insider's Panel, Beta Tester
Karl wrote:
Joeri, you are seeing these Finder issues with 12?
I'm on OS 10.5.5 (Intel).
Issue 1 and 2 with AC10 or AC11 : frequently, with AC12 : rarely, but it happens.
Issue 3 with AC10 : not seen yet, with AC11 : regular, with AC 12 : once a week...?
Erich
I notice that all the folks that have this issue are on Mac OSX 10.5X (I think). As I have never experienced it myself, I am wondering if this is related to running Leopard.
Just a thought.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Certainly Leopard!
The same applies to the ATI graphic display issues. No problem at all with OS 10.4.(9).
If you don't feel the need, please do not upgrade. I (have to / want to) stick with Leopard only because of the Time Machine implementation...
Ralph Wessel
Mentor
No, I've had this problem for several versions of both ArchiCAD and the Mac OS. The same problem crops in several other threads, including a related problem with Spaces. It only happens with ArchiCAD, so I assume this is something GS need to address.
Ralph Wessel BArch
Software Engineer Speckle Systems
SeaGeoff
Ace
Agreed.
Regards,
Geoff Briggs
Barbara Sommer
Graphisoft Alumni
Graphisoft Alumni
We have been able to reproduce this problem at Graphisoft Tech. Supp. several times using "Spaces" while working with ArchiCAD. But unfortunately we could not find any clear method/steps yet to replicate the problem constantly. This is a bug that needs to fixed as soon as possible and since many of you have had similar issues we would be glad if somebody found a way how to 100% and constantly get this bug alive.
We would like to reward the first user who can provide us with these steps with a Graphisoft T-Shirt.
Barbara Sommer
Technical Support Team
Budapest, Hungary
archicadwiki - the ArchiCAD knowledge base
