AC15 loading library each time a new file is opened
Hello, We've recently made the transition from AC11 to AC15. In version 11, the library would load only when we opened Archicad for the first time. In version 15, it would seem that the library reloads every time we open a file.
Over a WAN/VPN, the library load takes 15 minutes so once a day is ok, but on every file it because a bit of a problem.
Any suggestions?
1 Reply 1
The libraries have always loaded each time a new file is opened in all versions of AC, even 11. It is the PLN file itself that says what libraries to load, and where they are...
Sounds like a network problem - however over WAN/VPN you should be loading local copies of the standard libraries (assuming you are not teamworked) - not from the remote server.
