Vasileios S_
AC18 Tiny Window Palettes - Cannot resize them
Hello everyone,
Two of my most important palettes, Coordinates and Control Box, are now tiny and I cannot resize them. I attach an image.
I used to have these two palettes on the bottom of the screen. I realized that the main working screen got bigger and bigger until it took almost everything of the palettes. I cannot resize them and even when I put them on the top of my screen, they are still tiny.
Any ideas?
Vasileios
You cannot build a line.
1 Solution
It looks like they are being cut off or covered by something.
Do they appear the same if they are free-floating?
What happens if you re-apply your work environment (or the standard one)?
Go to post
4 Replies 4
Vasileios S_
Barry,
It worked! Reapplying the work environment profile worked!
Even when I closed and opened ArchiCAD, it kept showing part of the palettes. Your process worked!
Thanks a lot!
Vasileios Stergioudis
P.S. Is there a button that I can show the problem as "solved" ?
Yes, there is an 'accept answer' button in the top right of every post.
I have activated this one already so yo should see a green tick now to say it has been solved.
Anyone that now clicks on the green tick will be taken directly to the post that was marked a solving the problem.
Vasileios S_
Thanks a lot Barry.
Vasileios
