Nuge
AC22 MARQUE - SPEED TO GENERATE 3D WINDOW
I have recently been noticing that the time to generate/open the 3d window has increased in AC22, and to my surprise if i use the marque tool to select an area to view in 3D it doubles the time to generate as opposed to just opening the 3D window
I just tested with a standard model and with exactly the same model
WITH MARQUE 24 seconds
WITHOUT MARQUEE 11 seconds
Can someone please confirm this is a bug? and is there a workaround?
AC27 i9 14900KF / 128G ram / GTX 5090 / D5 Render
3 Replies 3
felcunha
Not for me...
Showing the marquee content is actually faster than showing all the 3d.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
Nuge
Felcunha
Thanks for the reply can you clarify that you put a marque around the complete model so that you are ending up with the same content in the 3d window (ie the complete model in both scenarios)
Nuge
felcunha
Nuge,
I have not seen any diference. Maybe because I'm using a mac ? Anyway, I din't notice the delay you've mentioned.
