AC24 problem with 3d view
Good day,
Windows 10 20H2 64 bit, AC 24 64 bit, local user rights.
When I try to switch to 3D view in the project, a memory overflow error occurs.
When I try to do the same under administrator or with "as administrator" rights, everything works fine.
What could be the problem?
1 Reply 1
Minh Nguyen
Thank you very much for the report and I am very sorry about the experience!
Based on my experience, the user rights should not have an effect on hardware operation. Could you make a screenshot of the error? Furthermore, does it happen with every file or with a certain file only?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
