Installation & update
Add On Internal Error
I just uninstalled older versions of AC (8 and 11)
Now when I open a project ( in 12 ) i get the error
Details: Unable to gt goodies from Archicad
NOTE.
I have been using 12 with no issues...only after I uninstalled 8 and 11.
Windows and Doors are missing and don't appear as options when i try to open the dialog boxes?
Currently on AC 12. XP
1 REPLY 1
Eduardo Rolon
Check your library settings (under File) and make sure that you have loaded the AC12 library and AC11 Migration Library. It is possible that you were working on AC12 using AC11 libraries.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
