Adding Memory To Archicad
up to os9 you could specify memory allocation for applications
osX does this dynamically and cannot be set by the user
if AC is using the hard disk for 'swap' memory then all you can do is close other applications or add more physical ram
in utilities>process viewer you can check if AC is running out of physical memory
bill
Aussie John
OSX will use all of your RAM - you cant change that (Hip hip Hoorary!!). Memory management is superior to OS9. If ArchiCAD goes to the background it will release Memory for other Programs.
The only thing you can do is GET more RAM
Cheers John
[/size]
