2006-07-25 09:14 PM
2006-07-25 10:38 PM
2006-07-25 10:47 PM
2006-07-25 10:53 PM
2006-07-25 11:09 PM
archislave wrote:it all works just the way you want it . . .
Does anyone know whether the might mouse can be programmed to pan and zoom like a typical wheel mouse when used in Archicad? I think the MM scroll ball is meant for up/down and side to side scrolling in a document.
In Archicad typical wheel scrolling becomes zoom in and out. Same in sketchup and autocad. So .... will rolling the MM ball do the sam? I wonder since the ball is omnidirectional and not constrained to up and down - it might confuse Archicad etc...
Would pressing down the MM ball pan as it does when pressing a wheel?
2006-07-25 11:11 PM
henrypootel wrote:
Hi.
You can make the Mighty mouse panning zooming etc work by deleting this file:
Macintosh HD:System:Library:Extensions:AppleHIDMouse.kext
Then reboot, and the wheel will work in Archicad the same as any other wheel would.
archislave wrote:it stuffs it up.
How does this affect the useful omni-directional scrolling in other apps?
2006-07-25 11:14 PM
henrypootel wrote:no it doesn't - see my response above... any movement of the mouse between the 0º and 180º (i.e.
-scrolling the ball left and right pans to the left or right
2006-07-26 12:40 AM
2006-07-26 12:51 AM
archislave wrote:as long as you're on the latest patch of archicad 9 or using archicad 10 it works the way you want it to.
Now I'm really confused ...
2006-11-05 10:23 PM
